Offroad & 4x4
79 - 86 axles
Old Jul 25, 2005 | 10:55 PM
Jebadiah04's Avatar
Jebadiah04
79 - 86 axles
ok lookin to SAS my trucky right....
well got a 79 axle in line to go under my 86
same width or is one shorter than the other?
Old Jul 25, 2005 | 11:00 PM
fishmanndotcom's Avatar
fishmanndotcom
78/79 have a narrower spring perch width than all the others. but you can make do. it wont be a bolt in you will have to make new spring mounts up front
-cutts-
Old Jul 26, 2005 | 11:03 AM
ivanribic's Avatar
ivanribic
It's easy enough to widen perches on front axles so 78/79 into later models is no problem. It's the newer axles in an older truck that are a major PITA.
Old Jul 26, 2005 | 01:10 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
newer ones shave 36.5 perch width, 78/79 are 32.5
Old Jul 26, 2005 | 05:39 PM
Jebadiah04's Avatar
Jebadiah04
well fumble butt....ill make it go
Old Jul 26, 2005 | 06:13 PM
fishmanndotcom
now is that centerpin hole to centerpin hole? or what? that sounds kinda short
cutts-
Old Jul 26, 2005 | 07:46 PM
Thomsen's Avatar
Thomsen
Yep centerpin to centerpin...i have measured many times.
Old Jul 27, 2005 | 02:18 PM
TallGuy_Az's Avatar
TallGuy_Az
According to his profile, he's got an F150.
Coils. Yeah, it'll work. I just put a solid D44 under my 81.
Old Jul 27, 2005 | 02:36 PM
Stroker_Deezel's Avatar
Stroker_Deezel
the axle he has is my coil sprung dana 44... he is going to straight axle using coils.
Old Jul 27, 2005 | 05:43 PM
Jebadiah04's Avatar
Jebadiah04
Yeah thats the plan 86 F-150 SAS
