timing without a light
Old Jul 25, 2005 | 05:01 PM
edsf100's Avatar
edsf100
Wondering if one could adjust/check the timing by just using a vacuum gage. Engine is a 390 that runs good but does pop out of the carb once in a while. Water temp is 200 to 215. Suspect timing but need to get a light. I have a gage and figure I'd try this first.
Old Jul 25, 2005 | 05:22 PM
EgoMan's Avatar
EgoMan
Anything you could do would be guessing at best...Which isnt to say you couldnt get lucky but the auto parts store has them for like 20 bucks.
Old Jul 25, 2005 | 10:57 PM
Hypoid's Avatar
Hypoid
https://www.ford-trucks.com/forums/s...d.php?t=296937
Probably more than you wanted. The vacume guage at least quantifies something, but it's no replacement for a timing light.
Old Jul 25, 2005 | 11:10 PM
Randyb12's Avatar
Randyb12
You should get a light but advance the timing alittle and see if that helps. It sounds a little retarded.
Old Jul 25, 2005 | 11:13 PM
edsf100's Avatar
edsf100
Thanks for the reply's. I'm going to get a light. Harbor Freight didn't have any in stock when I went there today. Any recommendations out there?
Old Jul 25, 2005 | 11:51 PM
Bear 45/70's Avatar
Bear 45/70
You can rent on from a lot of auto parts stores. But buy one though, timing with any other device is a good way to burn your engine up.
Old Jul 26, 2005 | 12:05 AM
ford390gashog's Avatar
ford390gashog
kragen has them from 25.00. the vacuum gauge idea works great if you have the time to do it. i set mine to run a perfect vacuum of about 23 then brought it down to 20 to prevent pinging. it runs strong and after hooking up a timing light it showed 13 btdc.
Old Jul 26, 2005 | 11:11 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Timing with a vacuum gauge was great when you had the idle vacuum spec, but that sort of timing method went out with oil-bath air filters and flatheads
I remember reading old Chilton/Motor's manuals and they had an idle vacuum spec, but there's really no way to get it right these days without a timing light.
Actually, I think back then it was more important to make sure you had enough vacuum than to get the spark timing perfect.
Old Jul 29, 2005 | 11:17 AM
edsf100's Avatar
edsf100
Got my light from Harbor Freight and found timing over 15+BTDC. set to 8 and she runs much better. Thanks for the replys
Old Jul 29, 2005 | 11:44 AM
krewat's Avatar
krewat
Just for grins, did you check how much vacuum you had?
Old Jul 29, 2005 | 11:53 AM
edsf100's Avatar
edsf100
I'm running a edelbrock cab. Does it manner which line you check from?
Old Jul 29, 2005 | 12:02 PM
Randyb12's Avatar
Randyb12
Yes, from the front the port on the right (drivers) side is full vacum. the other is ported (no vacum at idle). Just to be sure pull the hose off while the truck is running if you have vacum at idle you have the right port.
Old Jul 29, 2005 | 12:31 PM
Bear 45/70's Avatar
Bear 45/70
Running manifold vacuum at idle is not correct. There is no vacuum at idle on the ported vacuum port so you will run initial timing at idle (the correct way). You only want vacuum to the dist. when at higher rpms. The vacuum advance is to help gas mileage, not correct idle problems or incorrect adjustments. If you are after high performance then run no vacuum as all. Real race motors run mechanical advance only or electronic advance if timng is computer controlled
Old Jul 29, 2005 | 12:40 PM
Randyb12's Avatar
Randyb12
He was asking for a port to read vacum with a gauge.
Unless I misread his post. If he was asking for the dist. He wants the ported one on the left.
Old Jul 29, 2005 | 02:58 PM
edsf100's Avatar
edsf100
I will check that out this weekend. Port on the right. What reading should I see?
