1978 - 1996 Big Bronco
Transfer Case Stuck in 4x4; help!
Old Jul 25, 2005 | 10:13 AM
lbianc1's Avatar
lbianc1
A couple days ago I noticed a noise which was going with the rythm of my tires spiining. It stopped when the vehicle stopped. I got out and had someone pull it forward and backwards while I looked underneath it and noticed that the front driveshaft was spinning as the truck moved. It was not shifted into 4x4.
I tried locking the hubs to see if 4x4 still worked and it did. I think the transfer case is just stuck somehow.
Has anyone had this problem?
I have a 1989 Ford Bronco full size with and AOD transmission and manual loccking hubs with manual shift transfer case.
Old Jul 25, 2005 | 10:17 AM
jem270's Avatar
jem270
Have you tried backing up 100 feet to see if it would disengage? I had to do it in mine once even though I have manual hubs.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old Jul 25, 2005 | 10:34 AM
lbianc1's Avatar
lbianc1
I hadn't tried that. If it is as simple a fix as that, tha would be great.
Old Jul 25, 2005 | 03:51 PM
lbianc1's Avatar
lbianc1
anybody got any other ideas or suggestions on this problem? I plan on going home this evening and driving in reverse down my street. If that doesn't work I was thinking I would just have to pull the transfer case and bring it somewhere to get looked at; maybe rebuilt.
Old Jul 25, 2005 | 04:10 PM
poffutt's Avatar
poffutt
Try posting this question in the forum Transmition, drive train etc.
