tool size help
Old Jul 25, 2005 | 10:00 AM
les erzinger's Avatar
les erzinger
Question tool size help
i will need to put new locking hubs on my 84 f 150 ford 4x4 p/u with a ttb dana 44. so might as well repack the wheel bearings also right? i have no idea what size socket/spanner wrench i need to remove the rotor/hub assy. went to a auto parts store to ask what size they where. said they did not know. so i'm sure someone here knows. thanks for any help..........Les
Old Jul 28, 2005 | 01:22 PM
les erzinger
please help
please help with the size spanner i need .
Old Jul 28, 2005 | 07:43 PM
beeboy's Avatar
beeboy
inner diameter is 2 1/16, outer is 2 3/8
http://www.tellico4x4.com/catalog/sp...na-p-6842.html
Old Jul 29, 2005 | 05:23 PM
GreenSubmarine's Avatar
GreenSubmarine
Most parts stores have a Dana 44 spindle nut socket. It will have 4 pins on it to mate with the notches in the spindle nuts. They usually run about $25 bucks. Additionally, you'll need a set of hex keys in SAE sizes for the hub face, a pair of snap ring pliers, a small pick for the outer ring, a seal puller (or thin cold chisel), a hammer and a big drift punch for your brakes. That's about it unless you replace the races for any reason, then you'll need a long drift pin or punch. Both sides complete is about a 4-6 beer operation.
And by the way, since your parts guy doesn't know what you're talking about, find a new parts man. It'll save you hours of frustration later.
Good Luck,
Ernie
Old Aug 2, 2005 | 11:13 AM
les erzinger
Talking
thank you very much guy's. got every thing else to do the job. just needed the sizes.
yep will go to another parts place from now on.
cant think of anything better than repacking bearings in 95* heat and fire ants biting the hell out of my butt
yee haw
