Distributor
Old Jul 24, 2005 | 07:50 PM
Southernguy101's Avatar
Southernguy101
Distributor
Ok #1 cylinder is firing ever now and then so iam replaceing the distributor with a earlier point type. What all do i need. I am going to get all of the following
distributor,cap,coil,rotor button,plugwires. Is that all i need ?
Thanks
Old Jul 25, 2005 | 12:19 PM
Southernguy101
anyone?????
Old Jul 25, 2005 | 03:42 PM
200000+F150's Avatar
200000+F150
You would also need a resistor or resistor wire to the coil, but WHY would you get rid of the electronic ign for a points type? Yeah, it's simpler, but horses are simpler than cars. don't mean I'm gonna trade down. (unless gas goes up some more).LOL
Old Jul 25, 2005 | 04:50 PM
oldhalftons's Avatar
oldhalftons
you'll need a condenser too.
make sure you have a dwell meter when you fire it up with the points.
Old Jul 26, 2005 | 10:16 PM
Southernguy101
What could i rig up to hold the new coil in place
Old Jul 27, 2005 | 01:44 AM
fordflaresides's Avatar
fordflaresides
You don't necessarily need a dwell meter, while it probably is a little more accurate you can set the points with a set of feeler gauges. Set the dwell before the timing. Also when working with old points distributors when you're putting the condenser and points in make sure none of the wires ground out on the base plate.
Old Jul 27, 2005 | 08:40 AM
Southernguy101
the new distributor came with the points so i dont have to but them iam planning on putting everything on the truck today i'll keep u guys posted on how it's coming
