Trans xmember
Old Jul 24, 2005 | 12:44 PM
dmonnin's Avatar
dmonnin
Trans xmember
Help...bought my son 90 regualar cab, 2.3, 5 spd. The trans xmemeber is see thru and have had no luck at the bone yards. Can anyone tell me what other years will fit or even later model that i can modify?
Old Jul 24, 2005 | 01:07 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Look for one from a 83 - 92 2.3L they are all the same gerneration Ranger. Also make sure the doner truck has the same trans as yours. There are 2 different trans that went with the 2.3L and I don't know if the cross member is the same between the two.
Welcome to FTE!
Old Jul 24, 2005 | 01:50 PM
dmonnin's Avatar
dmonnin
thanks
The problem here in the rust belt seems to be its a common part to rust out....was curious if i could go several years later and do whatever mods needed.
Old Jul 24, 2005 | 03:40 PM
TigerDan's Avatar
TigerDan
I'm not sure if an earlier one will fit, maybe just back to '89. I have an '89 as well as an '83 and '84, and the earlier ones have a crossmember that bolts directly to the frame, while the '89's crossmember attaches to brackets on the frame with rubber bushings. I don't see why you still couldn't use an earlier one, however. I'm not sure if the mounting holes are in place, you may have to drill new ones. -TD
Old Jul 24, 2005 | 04:40 PM
G2IC_Wraith
I haven't tried this yet, but I have seen comercials in my area that say Auto Zone will get you the used parts you need. It may be worth a shot.
