78 CrewCab a/t conversion
Old Nov 25, 2002 | 12:38 PM
sluggo36's Avatar
sluggo36
I have a 78 CrewCab 4x4 that I bought to work on this winter. It has a 351M that will be the first thing to go and a manual trans. I have a 76 F250 with a 460 and I plan on rebuilding the 460. My questions are: will the C-6 from the 2wd truck work with my transfer case without lots of modification and does anyone know a reliable engine shop in the Seattle area? I've read tons of posts about 460 building and I have a good handle on what I want to do. I am a little worried about finding the right guy to build my motor.
Thanks for the help.
Rob
Old Nov 25, 2002 | 06:19 PM
idahocrewcab's Avatar
idahocrewcab
I replaced the NP435 in my '77 CC 4x4 with an automatic. I used an automatic out of a van. I had to change the output shaft, and housing to one that came from a 4x4. Note that my CC has a divorce mounted transfer case. I also had to move my transmission crossmember towards the rear and down a little to accommodate the new location of the transmission mount. Some trucks have both of these mounting holes already in the frames, some do not. With your married transfer case, I would still expect that you would have to change your output shaft and tailshaft housing on your tranny.
Can't help you with the engine shop.
Good luck.
Old Nov 25, 2002 | 07:47 PM
highboy_73's Avatar
highboy_73
