Clevis Pin
Old Jul 23, 2005 | 08:04 PM
seawulff's Avatar
seawulff
Question Clevis Pin
Where can I find a replacement clevis pin which holds the brake pedal connection to the master cylinder? None of the usual suspects ie. Mac's, Dennis Carpenter, Sacramento Vintage Ford, NPD, carry them. Is there an alternative way to make this connection?
Old Jul 24, 2005 | 01:01 AM
dylan1952's Avatar
dylan1952
Welcome, Hey tell us about your truck what year and so forth. Depending on the year and series can't you find a replacement at the local auto parts place or do you have something unusual. If you can't find a pin could you measure it and weld up your own pin? Let us know what you got.
Dylan1952
Old Jul 24, 2005 | 01:25 AM
51ford fan's Avatar
51ford fan
I bought my clevis pin from my local Ace Hardware Store.
Old Jul 24, 2005 | 10:17 AM
pootscratch89's Avatar
pootscratch89
Lowe's and Home Depot have some unusual bushings and pins in their hardware bins; you might be surprised...
vernon
Old Jul 24, 2005 | 10:58 AM
Earl's Avatar
Earl
Hey dude - get that gallery set up with pictures. We get all edgy when we don't get our fix of pictures from forum members.
Don't know what year you have and what your brake setup is. I twisted the eye end off my 56 brake master cylinder rod when removing it (threads were rusted solid). If you check in Earl's World in my signature block below, there is a discussion of how I repaired it. It was a bit of work, but I got an exact fit when I was done.
Old Jul 24, 2005 | 11:14 AM
Okie-Dokie's Avatar
Okie-Dokie
Go to your local farm store. I like Attwoods and Tractor Supply.
Old Jul 24, 2005 | 12:04 PM
Earl's Avatar
Earl
I couldn't find an eye-bolt with the flat sides that the original had - even at McMaster-Carr or Tractor Supply. The ones I did find had the normal cast ID, not a bored ID so a cross-pin would ride nicely and not get ground up by the cast surface on the eye-bolt.
Old Jul 25, 2005 | 03:06 PM
seawulff's Avatar
seawulff
Hey, ACE and HomeDepot came through. They had a universal pin that I can cut to the desired length. How do you set up a gallery on this site? My "ride" is kind of garage bound at this time since the engine hasn't even run for 12 years, that's my next project.
Old Jul 25, 2005 | 05:16 PM
Earl's Avatar
Earl
Click on the User CP (User Command Post) link near the top of the screen. Then click on Edit Gallery and you can play around to create albums and add photos.
jhweigel
Apr 2, 2015 06:40 AM
McGiver
Dec 17, 2009 09:19 PM
sixpack664
Oct 2, 2006 08:58 PM
youdog99
May 9, 2002 10:55 PM
