Differential fluid change
Old Jul 23, 2005 | 02:12 PM
1995fordf150's Avatar
1995fordf150
I have a 95 F150 2wd. I have the inline 6 engine. I assume I have the 8.8 rear end. I will be changing the fluid and gasket. Haynes manual just specifies a ford part number for the recommended fluid and does not give viscosity. Could someone please tell me what viscosity I should use? I have heard before about a rubber gasket that is made for these rear ends and can be used in place of the regular cork gasket. Does anyone have any information on this?
Old Jul 23, 2005 | 07:20 PM
jim henderson's Avatar
jim henderson
I am guessing since I don't have an 8.8 . My 94 has a Sterling I think 10.something?
Seems like most of the rears around those years used a 75W90 and I think it specifies semisyn or syn. Older rears seemed to lean to straight 90 or 90W140, but I think that may be too thick for your newer diff.
Don't know if you need limited slip additive, I would guess not. But if you do, you can find it in big toothpaste tubes.
I have used the cork and rubber gaskets on different vehicles. I think I like the rubber a bit better. Seem less prone to getting cut while torquing. The gotcha I have seem with rubber is that sometimes it will squeeze out whilc torquing and then you have a big leak.
What I do is use some sealer, usually something like Permatex. I put the sealer on to the cover per directions and then put the gasket on that and let is sit a bit so it kind of keeps the gasket from squirming around.
Good Luck,
Jim Henderson
