Rear Mains???
Old Jul 23, 2005 | 02:00 PM
sneak's Avatar
sneak
Rear Mains???
Ok, we own two 02, f-350, crew cab, 4x4, srt. box, etc... the whole nine yards. Both are equipped with 7.3's and auto trannies. The newer of the 02, about six months newer, almost hit 100,000 mi. and the rear main seal went out. NOW, the older 02 is at about 115,000 mi. and we are 95% sure it's the rear main seal. Is there something about these 7.3's with or without the auto tranny that just eats these rear mains? Any advice or knowledge provided would be wonderful and greatly appreciated.
Old Jul 23, 2005 | 03:06 PM
barebackjake's Avatar
barebackjake
nothing on the rear mains that i know of. ive got some real high mileage trucks and havent had the rear main leak. i would check the high pressure oil rail plugs at the back of the heads the plug is about 1" round. they have 3500 psi against them all the time. ive had them leak on every truck ive had. and i know they redesigned the seals at some point the date i dont know though.
Old Jul 23, 2005 | 10:26 PM
fordDR's Avatar
fordDR
MANY PEOPLE MISTAKE A REAR MAIN FOR AN OIL LEAK HIGHER UP ON THE 7.3L CHECK THE VALLEY ON TOP LOOK FOR HIGH PSI OIL LINE FITTINGS LEAKING ( FORD HAS A REPAIR KIT FOR THIS PROBLEM ) ALSO A LEAKING TURBO PEDISTAL THE OIL FROM THESE WILL LEAK OUT A VALLEY DRAIN HOLE INTO THE BELL HOUSING AND CAN BE MISTAKEN FOR A REAR MAIN SEAL ( P.S THERE WILL BE OIL LAYING IN VALLEY IS THERE IS A LEAK )
Old Jul 23, 2005 | 10:51 PM
SoCalDieselFan's Avatar
SoCalDieselFan
Great info guys - thanks!
SoCal
F350 Diesel SuperNewb!
