Oil leak problem
Old Jul 23, 2005 | 11:52 AM
swampthing47's Avatar
swampthing47
Talking Oil leak problem
Oil seems to be leaking were the transmision and engine meet, is this a rear seal or something else?
It is motor oil and not trans fliud ,is it worth repairing ?
Swampthing47
1995 F150 4x4
150,000 miles
302 AODE TRANS
Old Jul 23, 2005 | 01:16 PM
johnsonswamp's Avatar
johnsonswamp
I could be a rear main, loose oil pan bolts on rear and/or a bad gasket, or a small valve cover leak on the back side and running down.
I thought my rear main was leaking for awhile but it turned out that a few rear oil pan bolts come loose.
Old Jul 24, 2005 | 08:40 AM
swampthing47
I will replace oil pan gasket and see if that cures it. all the bolts are tight.
Old Aug 1, 2005 | 02:29 PM
Volatile_Index's Avatar
Volatile_Index
My oil pan rusted from the inside out, it was a 95 with 125k miles on it.
Old Aug 1, 2005 | 05:23 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Volatile_Index, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
