7.3 tach problem
Old Jul 23, 2005 | 11:36 AM
babbler's Avatar
babbler
7.3 tach problem
when the trucks idling it reads zero and when i give it some fuel it comes up and as soon i let off it falls back to zero..
Old Jul 23, 2005 | 02:03 PM
justblowin'smoke's Avatar
justblowin'smoke
mine did that and it was the sender its by the oil fill and if i remeber right it cost around 60 dollars trough ford but that was a year ago
Old Jul 23, 2005 | 02:42 PM
babbler's Avatar
babbler
did it affect the shifting at all?
Old Jul 23, 2005 | 02:44 PM
justblowin'smoke
i have a 5 sp so i couldn't tell ya
Old Jul 24, 2005 | 10:38 AM
bilder12's Avatar
bilder12
All the information pertaining to the engine speed is fed into the ecm from the tach, the speed sensor and fipl (whatever its called) and the ecm determines which gear and all that crap to make it go. You may get away with removing the tach sensor and cleaning it, reinstall and see if that helps. Pay attention to the position and if it has one, the jamb nut. the tach sensor operates on the injection pump drive gear so you dont want it tight against it. Hope this helps you out.
Old Jul 24, 2005 | 10:40 AM
bilder12's Avatar
bilder12
oh shoot, do yo have a turbo indirect injection engine or a power stroke?
Old Jul 24, 2005 | 11:10 AM
babbler's Avatar
babbler
just a idi
Old Jul 26, 2005 | 11:27 PM
phish555's Avatar
phish555
Mine did the same thing. It did mess with the auto shifting. I replaced the tach sensor and it solved the problem. Justblowingsmoke is right, about $60.00
Old Jul 26, 2005 | 11:37 PM
PLC7.3's Avatar
PLC7.3
babbler go to quick links up top and edit a signature with truck info please...... thanks.
