front end lube.
Old Jul 22, 2005 | 09:49 PM
obdrifter's Avatar
obdrifter
front end lube.
Hello:
I own a 1968 hi-boy 390 4spd. 4x4 that I am doing some work on; do the work in the summer so I can have worry free winter driving. The front axle has big ball and socket joints at each wheel. Can anyone tell me what type of oil I should put in these joints?
Thank you, Ken
Old Jul 23, 2005 | 06:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Ken, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 25, 2005 | 11:06 AM
qman's Avatar
qman
I think you need a tube of bearing grease and a grease gun. You attach the hose to the grease zerk and pump in grease until it oozes from the rubber boot.
Old Jul 26, 2005 | 09:56 AM
obdrifter's Avatar
obdrifter
qman:
Thank you for responding to my question. I need to clarify the size of this "ball & socket" type joint. Each joint is about the size of a fist. There is no grease zerk, rather a plug like you would find on a differential. I removed the plug and stuck my finger down in there and found just a little oil. My problem is that I then figured I should use 85w differential oil, but after I put it in there it appeared to leak out around the ball. Bad move on my part.
ANy other ideas?
thank you,
Ken
(obdrifter)
Old Jul 26, 2005 | 11:48 AM
67and71_Carl's Avatar
67and71_Carl
obdrifter,
The factory reccomendation is 85W-90 gear oil. There have been discussions about this with some folks writing in that they used grease. On mine, I use Gear Oil. I'd be worried about how stiff the grease would become in the winter here in NY.
Old Jul 26, 2005 | 01:55 PM
1975Ford's Avatar
1975Ford
I worked at a Ford Dealership lube service center, I used the gear oil.
Old Jul 26, 2005 | 02:19 PM
qman's Avatar
qman
Can you guys tell me what the socket is getting lubed? And should it leak out all over the place?
Old Jul 26, 2005 | 02:27 PM
Fomoko1's Avatar
Fomoko1
Hi Ken, if the oil leaked out check to see if there is a seal and if there is it maybe shot. Sorry, I have no experince with this so that is all that I can suggest for you to check. When oil leaks out the seal is the cause most of the time. Also check for worn/damaged surfaces that could damage the seal. Try to get a look at a shop manual.
Old Jul 27, 2005 | 11:02 AM
67and71_Carl
Well, the first answer is that they will always leak--at least a little. That is why some folks use grease. There is a felt seal with a rubber wiper over top of that. They work OK. Not great. They are still available if yours is shot (and it probably is). As far as your question about what you are lubing, you are lubricationg the internal U-joint, as well as the trunnion bearings (upper and lower).
Old Jul 27, 2005 | 09:54 PM
obdrifter's Avatar
obdrifter
front end lube
Thanks for all the replies. Yes, it would not surprise me that the seals are shot. When I bought the poor old truck, it had spent many years sitting out in a field. Its a great truck, though. The 390 has the heart of a young horse, and doesn't seem to realize it is 37 yrs. old. The driveline is tight. The body--well, that is another issue.
It seems that the driver's side plug is rusted solid ( even heat would not budge it, so I can't check the oil level in the left socket. Well, I could with an "easy-out." The project continues.........
Ken
(obdrifter)
old ken
Aug 27, 2009 08:16 AM
backhoeken
18
Mar 23, 2007 07:19 PM
ken's 80
Jan 23, 2007 11:21 AM
BowhunterKen
Offroad & 4x4
Dec 15, 2003 04:21 PM
Ken2600
Dec 25, 2002 09:17 PM
