Sponsored by: Auxito
Belt replacement
Old Jul 22, 2005 | 05:30 PM
fireftnford's Avatar
fireftnford
Belt replacement
How difficult is a belt replacement on a 97 F150??? I have 102000 on the original and I think I got my money out of it. Ready to replace it.
Old Jul 23, 2005 | 06:58 AM
12swat's Avatar
12swat
Its pretty easy. Just use a ratchet or breaker bar to rotate the belt tensioner arm. There is usually a square hole in the tensioner arm for a 1/2" breaker bar or ratchet. Then pull the old belt off. There should be a picture of the routing of the belt next to the emissions sticker under your hood by the fan shroud. If not remember how it came off or draw a picture. Then put the new belt on the same way the old one came off.
Old Jul 23, 2005 | 07:29 AM
dlorenz's Avatar
dlorenz
I changed out my belt on my '97 4.6 at 150,000 miles - way too many miles, but the belt looked so good I kept it as a backup - I'd highly recommend Motorcraft as a replacement. As for the task, it wan't bad. Study the diagram under the hood carefully - maybe sketch it on an index card to use underneath - keeps you from doing the "up and down" when putting the new belt in. I did 2 things to help out - used a 1/2" flex handle with PVC cheater to position the idler pulley. Also made an "L" out of some 1/8" rod to help position the new belt around one pulley - it's a bit tight in a couple of places. Nothing has to be removed to change out the belt.
Old Jul 23, 2005 | 03:11 PM
fireftnford
thanks for the advice. I'll be giving it a try next week.
Keg1973
Apr 13, 2015 07:11 PM
Avid_Stroker
19
Sep 3, 2013 05:28 PM
DGM
May 17, 2012 07:36 PM
mwsF250
Oct 4, 2011 02:54 PM
jlmotox
1997 - 2003 F150
Feb 10, 2008 12:55 PM
