header questions
Old Jul 21, 2005 | 11:44 PM
352 blue's Avatar
352 blue
Question header questions
My machinist seems to think that headers on FE's are a bad idea that since the water jacket doesnt extend all the way to the exhaust ports and that they will overheat
Old Jul 21, 2005 | 11:47 PM
85e150's Avatar
85e150
Hhhuuhh? If that were the case, certainly they would overheat with the stock manifolds darn near flat against the exhaust ports, don't ya think?
Old Jul 22, 2005 | 12:47 AM
Randyb12's Avatar
Randyb12
Your machinist is full of it. I would find a new one.
Old Jul 22, 2005 | 01:07 AM
Hypoid's Avatar
Hypoid
So what is he getting at, cracks in the heads or exhaust runner? I guess a restrictive exhaust could hold heat in the motor, never really looked at it that way. A few decades back I read some FE write up in a Hot Rod mag. That author seemed to think that the exposed exhaust runner helped evacuate heat from the head and prolong valve life; sounded good to me.
Try a search, the problems I recall are:
1) How do I make them fit?
2) How do I make them seal?
Heat soak is another related problem. With more exhaust surface under the hood, you will also have more BTUs trapped under the hood. You will have to think about things like a heat shield for the starter, a fatter air/fuel mixture and optimizing spark timing to keep the burn in the cylinder. It's starting to sound like a freakin chebby, but a lot of people are happy with the switch.
Old Jul 22, 2005 | 09:07 AM
Putt's Avatar
Putt
Absolutely ridiculous!!!! Find another machinist.
Old Jul 22, 2005 | 09:15 AM
Craig5_12's Avatar
Craig5_12
I say go with what you know, it's not your machinists truck! Freeflowing exhaust has got to be better than restrictive...unless it's too freeflowing (i.e. big)
