4 speed trans.
Old Nov 29, 2002 | 06:13 PM
jetta4's Avatar
jetta4
4 speed trans.
I have a 1982 f350 2wd and want to know if a early 1970s 4 spd trans.( with reverse beside 1st gear ) will work in place of a t18 trans.? Also what is the 70s trans.? Is it also a t18?
Old Nov 30, 2002 | 08:53 AM
0u812's Avatar
0u812
4 speed trans.
Ford used the warner T-18 as well as the New Process 435 transmission for heavy duty truck applications during the 1970's, either one should interchange with your current T-18.
Old Nov 30, 2002 | 10:38 PM
82F100SWB's Avatar
82F100SWB
4 speed trans.
The 70's trans is most likley a T-18, they changed the position of the reverse shift rail in the mid 70's, and moved it from beside first to beside 4th.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Old Nov 30, 2002 | 11:09 PM
hawkrod's Avatar
hawkrod
4 speed trans.
