Daytime running lights
Old Jul 21, 2005 | 10:23 PM
Bob Jennings's Avatar
Bob Jennings
Question Daytime running lights
Hello:
1998 Ford Ranger, 4.0 litre.
The daytime running lights just recently starting staying on after the key is removed. The only way to stop from killing the battery is to disconnect the positive lead on the battery. Does anyone know if the DRL relay is the culprit? Where is it located and how can it be tested?
Thanks for your help.
Bob Jennings
Old Jul 21, 2005 | 11:34 PM
Franklin2's Avatar
Franklin2
This is the only diagram I can find that shows the DRL circuit. It is for a 1994 explorer.
http://www.autozone.com/images/cds/g...3d800ba9e5.gif
Looking at this diagram, and from what little I have learned about them, the module takes power and runs it through some sort of step down circuit and then sends the lower voltage to the highbeam lights. Looking at the diagram above, you can see the DRL module gets it's power from a seperate fuse. If we assume yours does the same, I would look under the hood and see if you can find a fuse that would power the DRL. Some vehicles have the fuse box under the dash only, and some have one under the hood and under the dash both.
If you could figure out the fuse, I would pull it, and see if the problem went away. One thing this would do is keep from having to pull the battery + all the time, and second this would be a clue that it probably is the module that is bad. Sorry, but I don't know were the module is located.
Old Jul 22, 2005 | 03:56 PM
aeomholt's Avatar
aeomholt
On my -92 econoline e350 the DRL module are located on the frame between the radiator and the bumper slightly over to the passenger side.
