I know this has been asked several times.. but here I go.. I have seen several posts when I searched reagarding the largest tires that can be run on a stock 4X4 expe.. I have a 2002 model and I am currently running 285/75r16 pro comps.. I seem to have room to run 33x12.50 or 305/70r16s if I want without rubbing? I saw one post where someone was running 315/70R16 on a stock expe? So what is the largest tire anyone has run on a stock expe? I am going to replace my tires and wanna fill the well to the max without rubbing...
Man I am going to stick with a 285/75/16 for full use. What I mean is I don't use my Expy as my primary offroad vehicle so I don't want to lift it. With that said I have been out and one beer led to another and next thing I know I am into some serious 4 wheeling. Now with all that said here is what I am getting at. If you want full use full suspension travel with the truck also on steep grades I believe a 285/75/16 is your limit (32") it is not the suspension that gets close to rubbing it is the front fender rear sheet metal. I thought I was in a situation once where I was going to crunch it but managed to find a way out. I don't doubt a 305/xx/16 will fit but I think you will be limited to light offroad. Look into the 2" daystar lift as an option it is really cheap. Also possibily a 4" but now you are talking 1000 bucks minimum. Good luck let us know what you decide.
I understand what you are saying.. It is no use of squeezing more rubber in if you can't use it and stand the chance of damaging your ride.. The only problem i have found is that the daystar lift only has a kit for the rear spring, and nothing for the front end... What do they expect us to do with the front end after lifting the rear?
I have 33inch BFG Mud Terrains and i have no problems with them rubbing on or offroad(2001 XLT). There is a user that has a 35 inch tire on a completely stock expi, all he did was space out the front bumper 1 inch so the valance wouldnt rub. He claims he has no problems and no rubbing. check his pics here: https://www.ford-trucks.com/user_gal...&albumid=11911
I was thinking of trying this, and Im not worried about rubbing or damaging the truck, i just dont want my gas mileage to be any worse than it is when im paying $65 to fill this thing every week!
Wow Mike, I never really searched for the 2' till I read your post. I guess the torsion bar guys are outta luck. Maybe someone will show us the hidden light. I leveled my truck witht the torsion bars since the rear sat higher but only about 1". 2" would be the death of the ball joints. I know there is a 2" body lift that would do the same but they are pretty much laughed at by the hardcore 4x4 crowd. Is the 4" out of the budget?
No, the 4" isnt out of budget, I was just curious as to why they made a rear coil lift when they had no options for the front .. Cranking your torsions an inch isnt a problem but trying to get 2 or more is suicide on you joints.. .
Don't worry about the "hardcore" offroaders, do what you want for your ride. When my current set of stock tires go out I will put on a 3" body lift and 35 X 12.50 tires with aftermarket backspaced rims. This will give me 1.5" additional ground clearance, larger contact patch with some float, and a slightly wider stance. If Ford had used a rim wider than 7" I wouldn't have to change the rims.
I was very please with the stock performance offroad (minus the steps) and this will only improve it. You're not going to take a daily driver full size SUV through Tellico or Moab anyway.
305/70/16 is essentially the same (33" high) as 285/75/16 just 4/5" wider. They supposedly work fine. I personally like the look of the 285/75/16 better and it "kinda" fits the 7" rim, whereas I'd be scared to put the wider tire on the same rim.
