Front Windows Binding
Old Jul 21, 2005 | 12:06 PM
moe1071's Avatar
moe1071
I recently installed in channel window vents on my 04 SCab. Everything fit nicely. When I tried to roll the windows up, however, the windows would not go the whole way up. Did anyone else have this problem on initial install?
Old Jul 21, 2005 | 12:10 PM
BruceFX4's Avatar
BruceFX4
Make sure the metal retaining clips are pushed all of the way in.
Old Jul 21, 2005 | 12:34 PM
moe1071's Avatar
moe1071
Thanks for the tip, but there are no metal retaining clips. These just slides right into the window channel.
Old Jul 21, 2005 | 12:58 PM
bobri's Avatar
bobri
don't know if this is a help to you ....and if you are talking about the plastic models that just fit in, I was getting some of the same problem when the window was going up near the top. I don't know if this is just a summer problem because I did not have the problem during the winter, however, I found that by leaving the window all the way up and letting that part of the truck sit in the sun for a couple of hours that it eliminates a lot of it for a while....I have to do this every once in a while during the summer months...
Old Jul 21, 2005 | 01:30 PM
moe1071's Avatar
moe1071
Thanks, bobri. That just may be what the problem is. They need to work themselves in a bit. I'll give it a try.
Old Jul 22, 2005 | 10:44 AM
bobri's Avatar
bobri
I don't know if it is the way they are designed and twist a little in the heat along with some very minor expansion with the windows down. hope it works for you.
