Sponsored by: Auxito
AC Vent Wierdness
Old Jul 21, 2005 | 08:40 AM
Racer_x's Avatar
Racer_x
AC Vent Wierdness
The vehicle:
2003 Ford F-150 Lariat,
"Automatic" climate control.
The problem:
Air conditioner only blows out defroster vents no matter what position the controls are in.
Additional diagnostic info:
When switched to "vent", the blower blows (hot) air out the dash vents. I removed the control unit and applied vacuum to the various hoses. The black hose appears to be the vacuum source from the engine (20-23 inches vacuum with engine running). The other hoses appear to actuate the vent flaps. Only the red hose seems to do anything. When I draw a vacuum on the blue hose, the vents switch to both floor and defrost. IIRC, drawing a vacuum on the read hose switched to the dash vents. The yellow hose and the white hose don't seem to do anything when I draw a vacuum on them.
I've ordered a new control head, but it's on backorder from Ford with no ETA yet (the dealer has been searching for about 3 days to try to find one).
First Question:
Will replacing the control head fix the issue with the vents? I know there's something wrong with it because I can make some of the other combinations work with my vacuum pump pulling vacuum on some of the hoses. But I can't get "panel/floor" or just the floor vents no matter which hoses I draw vacuum on. So I'm thinking I might have other problems.
Second question:
Where can I get a new control unit?
Old Jul 21, 2005 | 11:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
