Sponsored by: Real Truck
Running Problem
Old Jul 20, 2005 | 11:06 PM
zoom1954's Avatar
zoom1954
Running Problem
I have been having a ongoing running issue. 94 460 sd, in RV.
Hard to start, but idles fine once its cranks. Spits and pops at take off but you can pump the gas and it will get though it and then will run fine until you stop and take off again.
Replaced plugs, wires, cap and rotor, coil, fuel filter. I have been told it could be a weak fuel pump, but it seems unlikley that it would run so well on the interstate and up large inclines with a weak pump.(this problem has been on going for over a year)
I am wondering if it could be vacuum related. The units has a vac guage and I noticed when the engine starting missing and popping the vac guage goes into the negative. Something else i noticed is that when the guage maxes out and goes into the negative for a substaned time, the ac vents are effected.
Does anyone have any thoughts on what I can check?
Old Jul 21, 2005 | 04:51 AM
captchas's Avatar
captchas
Guest
accelerator pump inside the carb being worn out will cause that, try getting the carb rebuilt or a t/u kit for it.
Old Jul 21, 2005 | 09:58 AM
zoom1954's Avatar
zoom1954
Thanks, but it is a EFI.I wonder if a bad injector would react that way ? This one has about got me. Being in a 37 foot RV, no shops are willing to work on it
Old Jul 21, 2005 | 11:53 AM
99f350sd's Avatar
99f350sd
Well let me see!! Popping of any kind in the intake usually means a lean condition. Such as fuel pump or filter. Hard start Could be the same but my guess its not either of those esp if you can take it down the road and floor it and it pulls hard.
I would check map sensor coolant temp sensor for proper value's. Does it have a Maf device? Then that also. How many miles on this thing? Is the timing chain ready to take a hike? I would put a fuel pressure gauge on it to be sure. There's a regulator in there also.
Dick
