Aftermarket Products
Sponsored by: Worksport
remote starter question
Old Jul 20, 2005 | 11:04 PM
Proteus566's Avatar
Proteus566
Hey all,
I'm intrigued by the idea of adding a remote starter to current or future cars in my posession.
However, when looking at some on ebay, they say that they will not work on cars with manual transmissions.
Why is this? I know that if you start it in gear, the engine will stall immediately. But, are their other technical reasons you shouldn't put a remote starter in a vehicle with a manual? its easy enough to not leave it parked in gear. Thats what parking brakes are for.
Thanks in advance,
Alvie
Old Jul 20, 2005 | 11:45 PM
MemOrex's Avatar
MemOrex
Probably cause clutch has to be pushed in for the car to start
Old Jul 21, 2005 | 04:45 PM
mattd17's Avatar
mattd17
i have seen several options out there that will allow you to install them on manual transmission cars. part of the reason they are not as common though, is like MemOrex said, you have to have the clutch pushed in on most cars, so that switch has to be by-passed, and i then they have an extra module that you have to install. im not sure if it is a proximity switch of some sort to say that it is out of gear or what. all the systems i have installed were on automatics anyhow. keep your eyes peeled, or just find a distributor for the brand you want, and ask them. i would recommend crimestopper..... i installed a starter/keyless entry/window roll up module and i am very happy with it !!
Old Jul 21, 2005 | 07:09 PM
Maxium4x4's Avatar
Maxium4x4
Look up Astro-Start sold by Astro-Flex.
Astro-Start will work with manual trans. It is dealer installed system only. That is not a bad option since they work with these systems everyday. Mine has been great and I have a communication "2/way" distance of over 2,000ft......
Old Jul 25, 2005 | 11:11 AM
afinepoint's Avatar
afinepoint
Just be sure you drive the vehicle after you start it. Don't do the timer thing especially with diesels.
AFP
Old Jul 25, 2005 | 05:53 PM
Maxium4x4's Avatar
Maxium4x4
I have the remote start but what timer thing are talking about Finepoint?
On the standards the trans has a neutral switch and you have to set the E-Brake. It by-passes the clutch start switch.
Old Jul 25, 2005 | 06:29 PM
Proteus566's Avatar
Proteus566
Hey all,
Appreciate the input much.
Alvie.
