I just moved to FL and in the process I lost the key to my locking lug nut. I need to put new brakes on the 97 150. Any thoughts on how to get the locking lug nut off. It sticks out a little and I was thinking of putting a pipe wrench on it. The rims are aftermarket and I have no idea what happened to the key. I really do not want to take an air harmer to them but it might come down to that. Also anyone know of a good set of brakes for a 97 150 supercab?
well they shouldnt be too easy to remove, or that would defeat their purpose !!! anyways, do you have access to a small welder? i would try to put a snug fitting socket over the end of it, and tack welding it into place in a couple spots. since they arent torqued too tightly, then a ratchet should back it off without breaking the welds. i wouldnt worry about ruining the lug since you lost the key, but you will be out a socket if you cant grind the weld off. good luck, and post back if you get something to work !!
Find a socket that's just a bit smaller than the lug and hammer it on, I've removed a lot of them like this. A 12 point socket will work better than a 6 point socket.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Most tire shops have a tool for just this purpose, they often have lock keys that have been left behind after owners have replaced the security nuts with standards.
