help!!
Old Jul 5, 2001 | 08:40 PM
dwyermandm's Avatar
dwyermandm
help!!
i own a 1989 ford E350 with an ambulance package. I can not find the low side port for the a/c. I can find the high side at the rt top of radiator. the system is dual for crew and for the box. anybody know where the low side port is (or do you service from the low pressure swithc?
Old Jul 5, 2001 | 09:11 PM
whomrig's Avatar
whomrig
help!!
Always service from the low pressure side. I do recommend that you find a good shop to service this though. I did this type of work 20 years ago, and it really is better to let the pro's do it, unless you do that type of work.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 27, 2001 | 12:25 PM
AZ4x4f150's Avatar
AZ4x4f150
help!!
Old Jul 28, 2001 | 05:27 PM
jicysa's Avatar
jicysa
help!!
If you follow the low (suction side)pressure line from the reciever/dryer to about middle way of the engine compartment that is where you should find it. You will probably have to feel for it. It is extremly difficult to see.
Be careful to not to cross thread on service port due to lack of clearance . If you E-series is equipped with a Leece-Neville alternater tie your service line up to keep it out of the alternater fan.
Old Jul 28, 2001 | 11:12 PM
FTE Ken's Avatar
FTE Ken
help!!
The General Conversation forum is CLEARLY labeled:
"Topics do not have to be about automotive products. Anything goes so long as its clean. DO NOT USE THIS FORUM FOR QUESTIONS ABOUT YOUR TRUCK, USE THE APPROPRIATE SECTION!"
Thread has been locked.
Ken Payne
Ford Truck Enthusiasts Admin
sierraben
Dec 9, 2011 09:00 PM
jake00
104
Aug 17, 2007 01:47 PM
bigbaddorsey
19
Jul 25, 2004 10:30 PM
