Sponsored by: Real Truck
Steering stop adjustment
Old Jul 20, 2005 | 01:34 PM
2003V10F250's Avatar
2003V10F250
Does anyone know how to adjust the steering stop on a 2003. I need to adjust mine alittle, the tires rub on the springs slightly at just below full lock and I would like to keep that from happening if I can. I looked on the back of the front hubs and there is no adjustment that I can see. Any help would be appreciated.
Old Jul 20, 2005 | 03:26 PM
high ho silver's Avatar
high ho silver
check DC Special's Gallery pix. He shows a good easy fix for your problem.
Old Jul 23, 2005 | 11:45 PM
ROKNZRX's Avatar
ROKNZRX
I had the same problew with my 04 4x4 after the 6" lift and new tires. Only difference was it only rubbed on one side. I had my welder weld a small washer on the flat area that the stop hits and it was enough to stop the rubbing. I did test it by taping the washer in place first to make sure it was thick enough to stop the rubbing, then once I was satisfied I had it welded in place. It works great! Good luck~
