thermactor plugs
Old Jul 20, 2005 | 11:59 AM
justine's77ford's Avatar
justine's77ford
thermactor plugs
Need to replace the plugs in the rear and front (on the heads). is there an easy way of getting to the rear ones. from a previous thread, i was planning on drilling a hole in the firewall. but it looks like the plug is located in line where the bottom half and the top half of the cab meet. will something like jb weld or something like it work as a temporary fix. any suggestions?
the rear ones have the pipe (?) still attached. cut off and crimped shut.
77 ford f250, 2x4
460 attached to C-6
Old Jul 20, 2005 | 02:48 PM
partsman01's Avatar
partsman01
I had the back one blow a while ago, I just drilled through the firewall close to it, and after getting the bits out from the old plug, I then hammered in a new plug and made a stainless steel plate and screwed it on with some sealant.
Then after the front one burnt through, so had to move the altenator and cleaned the hole out and tapped in a new one there too.
justine's77ford
Aug 10, 2014 07:12 PM
Justin's Green Truck
Feb 26, 2010 10:01 PM
justine's77ford
Jun 18, 2006 04:27 PM
hoxiii
1966 - 1977 Early Broncos
Jan 30, 2004 09:11 PM
