Clak
Old Jul 20, 2005 | 01:26 AM
73TorinoSport's Avatar
73TorinoSport
Question Clak
I just got a 73 Gran Torino with the cleveland and there is a clakking sound coming from the engine. i was thinking it may have been a rod cap letting go, but it seems to be more top-end. coming from the right bank (cyls 1-4), i was thinking maybe a bent pushod. i pulled the valve cover and the rockers arms were all okay, but i couldn't really tell the shape of the pushrods just a glance. i was also told it could be excess carbonation in the cylinder(s). it only starts at about 2500 rpm and kind of gets louder as the engine gets warm. any thoughts would be greatly appreciated....thanks
Old Jul 20, 2005 | 07:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 20, 2005 | 02:12 PM
maples01's Avatar
maples01
It's bearings, I've had experience there, the oil gets thinner as it gets warmer, that's why it gets louder.
Cleveland's were synonymous about depriving the bottom end at high RPM, so what you have is an engine that has seen some high reving, there is a way to prevent this from happening, but only a rebuild will help you. I'd say you'll need to have the crank turned, how far is unknown until it's on the machine.
Old Jul 22, 2005 | 01:02 AM
73TorinoSport
well it turns out i was right. on the way home.....yeah......well it threw a rod. i think the rod cap let go and the piston went up and hit the valve which was down which pinched the pushrod and bent, because the valve is stuck and the pushrod is bent. the is a hole in the oil pan on one side and a large dent oppostie it. so after vacation, ill pull the motor and then the head(s). then go from there
Old Jul 22, 2005 | 01:21 AM
fmc400's Avatar
fmc400
MSEE
That really sucks. How many miles on that engine?
Old Jul 22, 2005 | 01:42 AM
maples01's Avatar
maples01
Dang, haven't heard of that unless it's been rebuilt before, I'd say you may be looking for a long block, machining alone will be high and may not save it. Why would you drive it like that?
Old Aug 2, 2005 | 12:02 AM
73TorinoSport
i think there's probably 150,000 miles on it. it was rebuilt around 97. i only drove it because i wasn't guite what it was and i thought i could make it home.
Old Aug 2, 2005 | 12:16 AM
roger dowty's Avatar
roger dowty
Same reason I would...curious...or had to go somewhere like work...or to show it just WHO was boss etc. ;=)
Old Aug 2, 2005 | 12:34 AM
maples01's Avatar
maples01
The one I bought started banging , I parked it quick, luckily I saved it, but machining killed me, had I thought about it, I'd have just bought a short block, it's the hidden machining costs that get ya. Engines cost too much to just abuse one, mine laid down because the previous owner was one of those, drive it like you stole it types, it catches up with you, so you aren't showing it who's boss when it's over.
Old Aug 12, 2005 | 03:09 PM
73TorinoSport
well it turns out the rod sheared in half. then the piston positioned itsel so the crank counterweights were grinding on it. and the rod bearing was gone. in shreds in the case. i got a short block lined up $300 though so its okay.
