I just put a deposit down on an 06 250 SD. The only thing the truck doesn't have that I wanted was the upfitter switches. I would think I can purchase these from the dealer and install them. Has anyone done this? Will the wiring harness be there.
Ok now I am getting impatient. Only one link works in the folder section. Still need some more info on this please.
05UPFITTERSWITCHKIT Each
$56.05
Complete kit to add Factory Upfitter switches to 2005 and newer Superduty
You will recieve the all of the following. A complete kit to add the Factory Upfitter bank of switches to run whatever accessories you like onto your 2005 or newer Superduty.
1-5C3Z13D730AAA bank of On/Off switches fits into existing panel on dash no cutting or drilling required.
1-5C3Z14A303AA Complete harnes with plugs to plug right into the fuse panel, you also get all of the necessary relays and fuses installed in the block which is integrated into the harness.
1-5C3Z2513546CAA Storage bin to fill the gap left after installing switches on some applications.
those are the ford part numbers. you can get them from powerstroke.com
