What is this sensor and wiring?
Old Jul 19, 2005 | 10:06 PM
LBell101's Avatar
LBell101
89 E350 with 7.3 Liter Diesel.
On the front of the motor near the oil filler (just to the left)
there is a large threaded sensor with a harness that goes through
the firewall at the drivers feet. On mine the wires under the dash
are cut up mostly but one set goes to a light bulb.
What does this unit do? Should I attempt to get it working again
or just get rid of the wiring?
Thanks!
Larry
Old Jul 19, 2005 | 10:30 PM
fellro86's Avatar
fellro86
if it is two wires and comes off the timing cover, it is the tachometer harness.
Old Jul 20, 2005 | 04:36 AM
trike1946's Avatar
trike1946
Sounds right. Tach sensor, even if you don't have a tach. My 90 has one and it has to do with the trans shifting, and I don't have a tach.
Old Jul 20, 2005 | 10:59 AM
BikePilot's Avatar
BikePilot
Yep its an rpm sensor.
Old Jul 20, 2005 | 10:00 PM
LBell101's Avatar
LBell101
Thanks, never would have guessed that.
Since it's not connected to aything, I just removed the wiring.
I've already driven it 4000 miles without it connected to anything.
Larry
