1966 - 1977 Early Broncos
Jeep A/C
Old Jul 19, 2005 | 04:47 PM
larryejoh's Avatar
larryejoh
Jeep A/C
Will the under dash A/C unit from a Jeep Wrangler fit under the dash of an early Bronco. I've seen them on Ebay and they look like they may fit.
Old Jul 19, 2005 | 10:22 PM
fordborn's Avatar
fordborn
see if you can get dimensions then check your clearance. If it will mount under your dash then you should be able to hook it up. May have to fabricate some compressor brackets but that should be fairly easy. Good luck.
Old Jul 20, 2005 | 10:34 AM
oh2bnok's Avatar
oh2bnok
The sale # 7987661635 looks like it would be the most promising. Although I would get some measurements of the space between the lower portion of the dash and the floor board. The unit looks like it may be a little deep for the EB. My a/c uhit has the motors mounted behind it so there is not anything hanging down in front below the vents. That piece may also interfere with your t case shifter. Not sure about the others how they would work as the motors and other parts mount above the vent areas which would put them up inside teh dash area.
DUBS27
May 26, 2013 06:35 AM
kobaltblue
Jun 27, 2012 05:54 PM
nikmish
Apr 25, 2011 09:45 PM
Sawsall
Dec 5, 2007 11:41 PM
maddmatt13
Aug 8, 2003 05:11 PM
