Airbag/blower motor
Old 07-19-2005, 02:44 PM
Finally's Avatar
Finally
Finally is offline
Airbag/blower motor
I posted this on the Superduty forum to no avail, so I will try it here. About a week ago I noticed my airbag light was on. I don't know exactly when it happened. And then I noticed my blower motor wasn't blowing any AC. The AC kicks on, just no blower motor. So I started pulling fuses and found a 10 amp fuse under the dash that is clear at the top, right corner. So I replaced it. Turned the key and it blew again. So I unhooked the airbag in the steering wheel and replaced the fuse, turned the key and it blew again. I have the AC selector to off, so I am assuming the power to the blower motor is off. I realize air bag stuff is touchy and don't plan on removing it anymore. I just want to make sure it is not something else before going to the dealer. The airbag light doesn't flash, it comes on and stays on. Let me know what y'all think. Thanks.
LJ
Old 07-19-2005, 03:10 PM
touchofgrey's Avatar
touchofgrey
touchofgrey is offline
LJ
I wouldn't play with an airbag error.....and as much as I hate to say it....the dealer is where you should go with it. Would hate to see someone get hurt.
Old 07-19-2005, 03:43 PM
Todd525's Avatar
Todd525
Todd525 is offline
you ever see one of them get tripped? Its a nasty thought that it comes that fast and doesnt knock someone out
Old 07-20-2005, 01:19 PM
Finally's Avatar
Finally
Finally is offline
Can anyone give the manual description of that particular fuse? I don't have a cover or a manual myself. It is in the block under the dash, driver's side. If you are looking at the fuse block, it is located clear at the top, right hand corner. It is a 10 amp fuse. Please and thank you.
Old 07-20-2005, 04:10 PM
touchofgrey
That fuse goes to the airbag module, and blower motor. If it is blown.....there is a problem. I will WARN YOU once again......the airbag circuit is not something to take lightly. Please let a dealer look at it.
Old 04-15-2010, 09:02 PM
Yougotthehit's Avatar
Yougotthehit
Yougotthehit is offline
Wow Im glad I searched and caught this one. Well guess what my 99 blower just stopped working and guess what the air bag light came on. Does anyone know what this could be?
Usaman
11-10-2016 09:31 AM
Jbway
1999 to 2016 Super Duty
06-06-2016 12:30 PM
FordLou
1997 - 2003 F150
30
12-06-2014 12:14 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
08-22-2013 11:28 PM
fixit5561
07-27-2010 01:59 PM
Quick Reply: Airbag/blower motor
