bad water spots.
Old Jul 18, 2005 | 08:46 PM
AF Mezkin's Avatar
AF Mezkin
bad water spots.
My Expy does not have the luxurary of using the garage. As a result it has developed a bad case of water spots, I tried automotive window cleaners and even white viniger. Nothing seems to work, does anyone have a solution or a product that is great for removing tough water spots off windows.
Old Jul 18, 2005 | 10:17 PM
TMartinLVNV's Avatar
TMartinLVNV
Try glass polish. Most of the major manufactures make it and you should be able to find it at auto parts stores. It is usually a paste.
Old Jul 18, 2005 | 10:43 PM
MisterCMK's Avatar
MisterCMK
If they are fresh, hose down the truck and use a towel to dry it. However, if they are older, try a clay bar. The clay bar will remove all of the contaminates in the paint. Once you use the clay bar, you will need to wax the vehicle since the clay bar will also remove wax.
Old Jul 25, 2005 | 02:12 PM
jimbob21rc's Avatar
jimbob21rc
after washing use a leather chemise to dry it and the windows, when i worked at the detail shop i had some blue cloth towels i would also use but some of the blue shop paper towels will work and i also used some foam glass cleaner. if your windows are tinted they may not have been cleaned properly before the tint was applied, if this is the case then you will not get them off with out taking the tint off.
Old Jul 26, 2005 | 11:34 AM
getnbz's Avatar
getnbz
i agree to use clay bar i used clay magic on mine and it made it look like showroom again. after you use clay go over with a good wax.
