wiring problems
Old Jul 18, 2005 | 08:21 PM
fordbubba8206's Avatar
fordbubba8206
Angry wiring problems
i need to get my truck started again, i dont know what went wrong but im 100% positive that my trouble is wiring. its a 1983 F-150 351W, 4 speed, 4x4.its got new battery, wires, plugs, solonoid, starter. i was driving it and all of the sudden it dies.
Old Jul 18, 2005 | 08:37 PM
220k-f-150's Avatar
220k-f-150
So whats it doin' now. Turning over,etc?
Might check fusible links.
Old Jul 18, 2005 | 08:38 PM
Lou Braun's Avatar
Lou Braun
I think that your truck has the Duraspark II ignition system. If so, the ignition module is bolted onto the driver's side fender liner. Look under the power brake master cylinder. The module looks like a 2" x 4" x 1" box with a couple of pigtail connectors coming from it.
A failed ignition module will cause the problems you are seeing. It is a 10 minute job to swap in a replacement module.
Lou Braun
Old Jul 18, 2005 | 08:40 PM
fordbubba8206
well it was turning over, but now it wont, but i think its bc of a dead battery. but when i put in a new battery, it wouldnt turn over until my dad pulled the truck with the tractor backwards, so i could coast it and drop the clutch
Old Jul 18, 2005 | 08:43 PM
fordbubba8206
it does have the duraspark II
ive got a wild idea, i pulled off the module of an 80 351 which has 6 wires and the 83 has 5 wires. would it work if i matched wires except one?
Old Jul 18, 2005 | 08:51 PM
220k-f-150's Avatar
220k-f-150
Ok, heres a rundown.
Check for spark.
If no spark, test for power to coil and module.
If power to coil, then first pull cap and make sure rotor turns.
If rotor turns, then I'd say problem is either coil or module.
If no power to coil or module, it will be troubleshooting time.
Old Jul 18, 2005 | 09:00 PM
fordbubba8206
no spark, how do i check power to coil, or module, rotor turns,
Old Jul 18, 2005 | 09:10 PM
220k-f-150's Avatar
220k-f-150
Do you have a test light or voltmeter to use.
Check for 12v power at bat. terminal of coil. Ignition on.
Its starting to sound like that module. and no you need the same module even down to the color at module where wires go in.
Old Jul 18, 2005 | 09:20 PM
fordbubba8206
I have a test light, but no voltmeter. I know im getting 12 volts at battery. Is there any way I can test the module to see if its working? How much does a new module cost?
Old Jul 18, 2005 | 09:29 PM
220k-f-150's Avatar
220k-f-150
With ignition on, using testlight, ground clamp and check for 12v at BAT. (+) side of coil. Igniton module run for about $20 for cheapy AutoZ. to $50-$60 for good one.
To test module is a confusing process to describe right away.
Old Jul 18, 2005 | 09:35 PM
220k-f-150's Avatar
220k-f-150
Sorry, you can check for power to module, it just won't tell you if its bad. The red wire and the white wire have power with ignition on.
This just test power to, not whether it works or not.
Old Jul 19, 2005 | 01:38 PM
Holmesuser01's Avatar
Holmesuser01
My '83 351W C6 has the Duraspark III. You will find nothing in your distributor besides a rotor and the cap/wires. I NEED to change my Dura III over to the Dura II. The computer is dying and my timing is allover the place!!!
Old Jul 19, 2005 | 06:44 PM
SmokyOlFord's Avatar
SmokyOlFord
From what I've read here, it's normal for the computer-set timimg to jump around. You need to disable it via the SPOUT line to set the timing by a light, then reconnect the SPOUT.
Sorry to leave you with a cliffhanger on how to do that, but I haven't read up on that part of the manual yet!
-Ed
Old Jul 19, 2005 | 11:34 PM
SmokyOlFord
Digital multimeters are running about 5 bucks nowadays. My local hardware carries them. They're almost like the stick-on digital clocks that were sold everywhere in the 80's, so it should be easy to find one.
Make sure the battery has a good charge and cables are clean and tight. New batteries have a very tiny charge to begin with. They are shipped dry, electrolyte isn't added till they're sold, so they are essentially in their discharged state.
The haynes and probably the chilton manual has testing procedures for the various modules with pictures to help guide you.
-Ed
Old Jul 20, 2005 | 12:41 AM
RR4E's Avatar
RR4E
When checking/adjusting timing.
Unplug the vacuum advance(hose on the front of your distributor) Plug it off with something like a golf tee(these work really well for a plug). Then hook up your timing light, and start the truck. You will set your timing from there, and once that's done, re-connect the vacuum line.
