Broken axle shaft
Old Jul 18, 2005 | 05:02 PM
aubtc's Avatar
aubtc
Unhappy Broken axle shaft
Sorry this might be long. I suspected the front differential of my 96 Explorer AWD was going bad. Pulled the front driveshaft, differential, and axle shafts so I could drive in 2WD while fixing the diff. Week later, the driverside front wheel fell off at 50mph. Apparently axleshafts hold the front bearing housing together. Replaced all front end components with new stuff (ball joints, brakes, left side spindle, rebuilt differential, and new axle shafts). After 3 miles, the right side outer CV joint blew its guts. My question is: is there an improper way to install the axleshaft that would cause it to break? and, did driving the truck in 2WD for a week, possibly have messed up the transfer case? I'm thinking that it might have been possible to fry the transfer case by causing it to constantly lock up for the whole week and now that everything is reinstalled it is still locked up and overloading the driveline when turning which is destroying the CV joint. Any help is greatly appreciated. Trying CV joint #2 today.
Old Jul 18, 2005 | 07:51 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
AVR2
Escape & Escape Hybrid
Feb 27, 2017 07:54 PM
Capt No Slack
2004 - 2008 F150
Jan 6, 2017 07:58 PM
maxum2550
Mar 10, 2016 02:11 PM
dpilot83
Dec 23, 2015 09:43 AM
fgroman
1997 - 2003 F150
Jun 18, 2015 02:42 PM
