Actual tech questions
Old Jul 18, 2005 | 03:49 PM
woody_d87's Avatar
woody_d87
Post Actual tech questions
Ok I know the title looks a little strange. But I have a few quetions. First, has anyone changed out the seals on an NP205 before? How hard are they to get out? And special tricks? What oil do I use when I change it. I was looking around and one website said motor oil and one says ATF. What other kind of maintenance should I do while I have the seals out. Are there any other quirks about the 205 that I should know about. Also, Mile Marker hubs. Good or bad? I found some for $60 and I figured if I was to break one, I wouldn't feel so bad(and the wife wouldn' be as mad) if I broke them instead of $120 warn hubs. And input would be great!
Old Jul 18, 2005 | 04:23 PM
ivanribic's Avatar
ivanribic
Yo!
The powers that be frown upon us using the chapter forum for tech so if this thread disappears it'll probably be in the axle and transmission forum. But, for some answers to your questions:
The seals on the 205 aren't hard to change at all. The old seals will just pry out or you can pound them out with a punch. To install the new ones you'd be best to pick up the tool for installing seals. I think Harbor Fright may sell them, not sure. Otherwise you can tap them in yourself using a piece of wood over the seal to keep even pressure on it. Clean up the seat really good before you put the new seal in, sometimes a little emery cloth isn't a bad idea. If you end up pulling any shafts you'll probably have to deal with the scary needle bearings. They can be a real nightmare but vaseline will help stick them in place so you can reassemble everything.
Milemarker hubs seem to do the job alright but personally I'd go for the Warn premiums which have a lifetime warranty. Then you won't feel bad at all when you break one.
Btw, for the t-case fluid just use gear oil, like you would in a manual tranny. ATF is for the aluminum t-cases, not the old school cases like we have.
Old Jul 18, 2005 | 06:58 PM
woody_d87's Avatar
woody_d87
Thumbs up
Oops I didn't know about that rule. I guess you learn from your mistakes. Thanks for the info. I was just trying to clarify so I didn't do something catastrophic to my nice t-case. Looks like I will keep a magnet close incase i do lose any of thoes little needles so I can put it all back together right. I was looking at the warn premiums and they are actually a little cheaper andthe standard ones at 4wheelparts. I might look into getting one of thoes seal install kits because I have quite a few seals to change when I get home. Thanks again!!
Old Jul 18, 2005 | 07:08 PM
FordPickup460's Avatar
FordPickup460
Have you ever been here Woody ?
http://broncograveyard.com/bronco/c-...nsfer_case.htm
Old Jul 18, 2005 | 07:13 PM
woody_d87's Avatar
woody_d87
Hey thanks. I didn't know they had the kit. I was thinking I was going to have to go get the seals individually!
Old Jul 18, 2005 | 07:15 PM
FordPickup460
The seal kit doesnt have too bad of a price either.
Old Jul 18, 2005 | 09:29 PM
Racerguy's Avatar
Racerguy
moved to proper forum
