intermitten wipers
Old Jul 18, 2005 | 12:57 PM
1978fordf250's Avatar
1978fordf250
intermitten wipers
hey guys i have a 1988 ford truck intermitten wiper setup. I got the whoel setup. I was wondering will it fit in my 1978 ford f-250?
thanks,
Jimmy
PS I didin't know if the plugs whre the same or not but just visualy lookign it looks the same but there may be slight differences...
Old Jul 18, 2005 | 01:08 PM
ford390gashog's Avatar
ford390gashog
simple answer is nope. you need one from a 78,79 truck
Old Jul 18, 2005 | 01:18 PM
73Custom's Avatar
73Custom
Yes it will work fine. You need to swap two wires to make the washer work. I have a '86 setup in my '73. The pickup harness has a two part plug, the smaller plug is two wires, swap the two wires and it will work great.
Marty
Old Jul 18, 2005 | 02:37 PM
ford390gashog
after 86 they changed the setup. thats what i was told the last time i asked about adding these wipers in to my truck
Old Jul 18, 2005 | 02:41 PM
73Custom's Avatar
73Custom
I guess I was under the impression it stayed the same through the mid '90's but I could be wrong... Any one know for sure?
Marty
Old Jul 18, 2005 | 09:06 PM
Mil1ion's Avatar
Mil1ion
The original poster can use a control system from a 77-78-79 without any alterations.
He can use earlier systems with minimal alterations.
AFAIK,The 86 & up were re-designed.
There is an article in the tech articles area.
Old Jul 20, 2005 | 02:37 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
According to Motorcraft.com the wiper/washer switch, and the wiper washer govenor, will interchange with 1980 to 1986 and 1987 to 1991 baseline f-series pickups. and 1991 to 1999 F-series trucks, select F-600 and above.
So changing the wires around in the small plug like the other poster said, should work for you fine.
Motorcraft Part # SW-1572-A - wiper switch,
Motorcraft Part # SW-2259 for the govenor.
Hope this helps,
Old Jul 20, 2005 | 02:06 PM
1978fordf250
please elt me know where i can get a intermitten wiper setup that works for my truck. I also need a good windshield washer tank,pump and everything. the only thing i have is the hoses running up to the cab and the wireplug that plugs into the pump. I need the rest.
thanks,
Jimmy
Old Jul 20, 2005 | 04:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
the tank and pump you can get on ebay for around $50. i have a switch and governer from a 88 in my 79, and the only thing i had to do was delete 1 wire and move 1 wire
Old Jul 21, 2005 | 01:13 AM
1978fordf250
oh yeah? i cant figure out what one i need to move maybe its jsut me. I will take a closer look at it and see the differences.
Old Jul 21, 2005 | 06:14 PM
tjc transport
i ain't rite
i am not positive, but i am pretty sure you have to move the black with white stripe over one position in the 2 pin plug to get the washers to work.
let me see if i can find the wireing update on the falcon site, and if i can, i will get back to you. it is on the tffn forum
Old Jul 21, 2005 | 11:01 PM
Mil1ion's Avatar
Mil1ion
I sent you an e-mail on the 18th about what you are looking for.
Please reply to it
Old Jul 22, 2005 | 08:13 AM
Dreamsickle's Avatar
Dreamsickle
I have sold many of these setups off of 80-86 for the 73-79 they work great.
(80-86)
When hooking this unit up the 2-wire connector for the washer has a green wire with a black stripe and a white wire with a black stripe the GREEN wire has to be on the terminal for the washer to work. The 2-wire connector will go on either way.
