Part Needed.....
Old Jul 18, 2005 | 09:49 AM
Grumpy Gramps's Avatar
Grumpy Gramps
Unhappy Part Needed.....
Does anyone have an extra gas pedal swivel for a '54 F100 - the short part that attaches to the end of the gas pedal rod. It snaps into the inside-top of the pedal itself. Seems the only way to get one is to buy the entire pedal linkage. Has anyone fabricated any?
Old Jul 18, 2005 | 06:49 PM
dylan1952's Avatar
dylan1952
Try Dennis at Recks and Relics in Ohio or Bob's F-100 in Riverside Calif. I'll bet you find. I have seen them made up by welders also.
Good Luck, Dylan1952
Old Jul 18, 2005 | 07:53 PM
e william's Avatar
e william
I HAVE ONE
Hey Gramps, I installed a Lokar spoon set-up on my 54, but I keep all my old stock parts for a rainy day...or a Grumpy Gramps day !
Do you still need it???
Ed
Just so you'll know, I think Mid Fifty's has the whole assy. for about $40.00 if you want a new one anyway.
Old Jul 19, 2005 | 03:37 PM
Grumpy Gramps
Exclamation
Hey 'e william' - YES! I want one. Let me know what you want for it.
I tried Mid-Fifty but they said they no longer have any single parts - would have to buy the whole setup. $40 isn't terrible if you need the whole linkage but it is when you only need a little swivel.
Old Jul 19, 2005 | 09:35 PM
e william's Avatar
e william
Hey...no problem. How about $Free from one 54 guy to another !!!
you just pay the ship cost to you...
Just to be sure what you need....this is the linkage that has three bolts holding it on the firewall, the bar goes up to the carb linkage on the engine side and the other end goes into the cab and has the short(apx. 1") pivot with ball end that pops into the rubber grommet in the back side of the gas pedal? Right?
What I will send you is the entire unit. The swivel piece that pops into the backside of the pedal is fixed in place and not removable...the whole piece is in great shape so you might just replace the whole thing.
Are you able to private message me so we can get the ship info right? and you can send just enough to cover the ship cost...any overage and I will put it in the box and send it with the part.
Ed
Old Jul 25, 2005 | 04:39 PM
e william's Avatar
e william
The gas pedal linkage is on the way......hope it helps out !
Ed
Old Jul 25, 2005 | 04:48 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
This is a prime example why this board is so wonderful!! Great people helping one another out to creat great trucks!
You guys are awesome
Bobby
Old Jul 25, 2005 | 05:20 PM
Grumpy Gramps
Appreciate your help Ed. Right now I'm making up a set of running boards out of 2" x 12" boards. Don't laugh, they look pretty darn good. I routed out the bottom where they sit on the brackets and will use leveling bolts to fasten them. They have a large flat head which sits very flush on the board. I originally had the boards stained to match the bed wood but decided to paint them black. Tomorrow I'll be making up the vertical sides and attach them with bisquits & glue. This will buy me some time before I get the $$ for "real" ones. Mid-Fifty is sending out the trim skirt so it should dress out pretty well. Can't wait to finish up the gas pedal.
Old Jul 25, 2005 | 05:39 PM
e william's Avatar
e william
Your bosrds sound good, I'm gonna dress mine with some pollished SS strips.
My bed is black walnut (not refinnished yet)
Got my new paint gun and chassis black in today so hopfully I can finnish the paint on the chassis and running gear and install ss brake lines.
Just dropped off the head at mach. shop for valve job and decking.
post some pics of those running board when your done.
later, Ed
Old Jul 25, 2005 | 05:43 PM
bobbytnm's Avatar
bobbytnm
Gramps,
Make sure you post a pic of those boards when you get them finished (or even before)That sounds like a really interesting idea!
Bobby
Old Jul 25, 2005 | 05:49 PM
edsf100's Avatar
edsf100
Ed, do you have any info on your Lokar spoon.
Old Jul 25, 2005 | 06:28 PM
e william's Avatar
e william
The spoon is just a basic chrome Lokar unit. bolted more up on the firewall than on the floor...with a cable thru the firewall. When I re-do the cab (again) I will use an intake mounted throttle linkage on the other end of the cable (for smoother cable movement).
If you look in my gallery you can see the pedal set-up I installed with the new tilt and floor shifter conversion....spoon is barely visible behind brake pedal. If I remember correctly...the spoon was apx. 35.00.
The brake and clutch pedals are alluminum that I pollished myself.
Old Jul 25, 2005 | 06:44 PM
edsf100's Avatar
edsf100
That's the one I've been looking for. Very nice.
Old Jul 26, 2005 | 07:49 AM
Grumpy Gramps
I will be taking some photos of the wood boards and how I'll be cutting & fitting the vertical pieces. Right now I'm trying to figure out how I will attach the rear part to the side panel (underneath) as I do not want to drill holes in the fenders for the wood. If I drilled the fenders for the wood boards the holes would be too far up for the steel or glass boards because of the differences thickness. I have an idea that I will show in the future photos. I just want to be able to insert "normal" boards in the future without having to fill holes and repaint etc. I'll give an update shortly.
Old Jul 29, 2005 | 11:06 AM
Grumpy Gramps
Thumbs up Thanks e william !!
Just received the gas pedal assembly. Thank you, but you should have kept the change. Appreciate your helpful hand (and generous heart).
Ed
