1978 - 1996 Big Bronco
Headers question...
Old Jul 17, 2005 | 10:57 PM
Nascar's Avatar
Nascar
Red face Headers question...
I have a Bronco 80 with 351m and manual trans. I want to put a set of headers and i want to know what model fit because most model don t fit with a manual trans. THANKS !!!!!
Old Jul 18, 2005 | 04:11 PM
Kemicalburns's Avatar
Kemicalburns
look for a set for a 78-79 with that same motor/tranny . 80-81 were funky years for the bronco making it hard to find stuff. you may still have to do some work on the headers themselves to make them fit.
Old Jul 22, 2005 | 09:34 AM
7fords's Avatar
7fords
when you get the headers on the truck cut the collector flanges off and weld your exhaust pipes onto your headers you wont have to worry about collector gaskets blowing all the time
Old Jul 22, 2005 | 09:44 AM
Kemicalburns
i do not advise that. the reason is when you rig flex's so does your exhaust and if it cant flex then your header tubes can crack. ive seen it happen many times with longtube headers on full size trucks . gaskets are cheap, headers arent
Old Jul 23, 2005 | 10:32 AM
7fords's Avatar
7fords
sorry to hear that, ive never had or seen that problem. been doing it for twentysome years no different than welding up a stock exhaust. actually you have more strength with the multiple tubes of the headers verses single pipe on each side with stock exhaust. dont run generic headers
Old Aug 1, 2005 | 02:19 PM
akmud's Avatar
akmud
I have a set of M.A.C headers if you want to buy them. I will sell them if you want them. I bought them for my '95 but it has no EGR hook up. They are not stainless. I sand blasted them and painted them with silver 1200 degree paint. I never put them on my truck but they are used and in good shape.
