Bell dinging....... nothing on??
Old Jul 17, 2005 | 07:16 PM
Sam_M's Avatar
Sam_M
This is my first post.
I have a 2001 exp. When I shut it off, pull the key out, then open the door, the bell dings as if I left the lights on or something. But every thing is off and key is out of ignition. This started about a month ago. I can not find out why the bell dings. It suppose to do this, only when you leave your lights on, or key is left in, or dome light left on. My Ford truck only does this if I leave some thing on, but the bell is ringing all the time, untill I close the door. What is doing this?
Sam
Old Jul 17, 2005 | 07:55 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Sam, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 17, 2005 | 09:25 PM
snoracerx's Avatar
snoracerx
it sounds like you may be having a problem with your ingntion switch i have had similar problems in the past like you describing and an ignition switch turned out to be the culprit after diagnostics
