Submerged Real Axle
Old Jul 17, 2005 | 02:30 PM
lyonexplorer's Avatar
lyonexplorer
Submerged Real Axle
I submerged my rear axle and hubs pulling my boat out of the water. I have an 05 Expedition EB 4X4. Do I need to have the hubs repacked and the differential fluid replaced?
With my 98 Explorer (not 4X4), the owners manual said that if the rear axle and hubs are submerged to replace the differencial fluid.
Old Jul 17, 2005 | 04:29 PM
Sanchez_315er's Avatar
Sanchez_315er
Take a small sample of the rear end fluid.. if it looks like oil, you're GTG... if it looks like brownie mix, then you definitely got water in there... I'm betting you're fine.
Old Jul 17, 2005 | 08:44 PM
Monsta's Avatar
Monsta
Sit. Stay.
How long was it submerged?
Old Jul 17, 2005 | 11:56 PM
lyonexplorer
5 minutes launching the boat and another 5 retrieving the boat. The owners manual for the 2005 Expedition says to replace the axle fluid if the axle is submerged.
Old Jul 17, 2005 | 11:58 PM
ford390gashog's Avatar
ford390gashog
i doubt any water got in.
Old Jul 18, 2005 | 04:53 AM
Monsta's Avatar
Monsta
Sit. Stay.
I'm gonna side with Sanchez on this. Take a sample. Why chance it...
Old Jul 18, 2005 | 09:28 AM
lyonexplorer
OK. How do I take the sample? I don't even know where you drain and re-fill the rear end.
Old Jul 18, 2005 | 09:35 AM
ohioclint's Avatar
ohioclint
Crawl under the rear in the center and find the thing that looks like a pumpkin, the driveshaft runs into it.
There should be two plugs in it. Remove the lower one and let a little bit out. If its been sitting awhile any water should come out first.
Good luck on putting it back in. Also, it will probably be nice nasty smelly gear oil.
Clint
Old Jul 18, 2005 | 11:54 AM
broncoholic's Avatar
broncoholic
You don't want to have to do this everytime you launch your boat. As a precaution for the future, find the breather and put a longer hose on it that you can route up near the body. You may have to replace the breather with a fitting that you can strap a hose on. After that, 5 minutes in the water won't be enough time to get any by the seals, as long as they're good.
Old Jul 18, 2005 | 12:20 PM
pitrow's Avatar
pitrow
Aside from the vent that broncoholic mentioned, the only other way for water to get into your rearend is through the axle seals or the pinion seal as he also mentioned. Assuming that both are still in good shape, then dunking your axle for 5 minutes shouldn't pose a problem. My theory is that if you're not leaking gear oil out of them, water is going to have a hard time getting in. I've done plenty of fording of streams in my Jeep and never had a problem, as long as your seals are still in good shape you should be fine.
Edit: just thought I'd mention one other thing...
If you've been working the truck hard on the way to the boat launch and rear end gets hot, dunking it in cold water can cause a negative pressure inside the axle, especially if the vent is clogged. This can sometimes suck water in past the axle seals.
Old Jul 18, 2005 | 06:17 PM
MisterCMK's Avatar
MisterCMK
Think of it as driving through a huge puddle. I wouldn't worry about it. However, check the fluid, and even change it. Its not a big deal to change the rear diff fluid, and its pretty inexpensive.
donberry
Sep 15, 2021 12:19 AM
BOHAWG175
Dec 18, 2017 08:03 PM
captainkirby
2004 - 2008 F150
Nov 15, 2016 10:19 AM
awq134
2009 - 2014 F150
Mar 31, 2014 10:36 PM
hozee4
21
Dec 21, 2009 03:09 PM
