drivetrain
Old Jul 16, 2005 | 08:06 PM
Bankz27's Avatar
Bankz27
drivetrain
I have a 92 f150 xlt 2x4 5.0L regular cap and I was wondering what type of back end do I have, what gear ratio, just want to know has much has possible to the drivetrain has I can
Old Jul 17, 2005 | 01:57 PM
johnsonswamp's Avatar
johnsonswamp
Most likely a 8.8" rear end, Get the tag numbers off the diff., or door jam and post them here so someone can tell you what gear ratio you have.
Old Jul 17, 2005 | 08:00 PM
Bankz27's Avatar
Bankz27
didnt see tag from diff and door jam was peeled off
Old Jul 17, 2005 | 08:50 PM
TallPaul's Avatar
TallPaul
You can always get approximate by seeing how many turns the drive shaft takes for one turn of the rear wheel, which would be the ratio. Best by rolling it along the ground so both rear wheels turn the same (open differential can play tricks when jacked up, not sure one wheel or both in air).
