4wd sounds?
Old Jul 16, 2005 | 03:12 PM
RA122225's Avatar
RA122225
Banned
4wd sounds?
Alright, I looked at a 1991 Ford F350 4x4, and when engaged in 4 wheel drive with the hubs locked, it made a growling sound, and almost sounded like something hitting the bottom of the cab (nothing was hitting.) The sound only occured during sharper turns, is this normal?
Old Jul 16, 2005 | 03:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Jul 16, 2005 | 03:52 PM
RA122225's Avatar
RA122225
Banned
Oh yeah, also, I called a Ford dealer, and he said it was the fact that the hubs locked the wheels to be going the same speed, and when turning the outside one had to go a lot further, but because they were locked, it made that sound. I was in a field by the way, on slightly hard packed dirt with a small layer of sand on top.
Old Jul 16, 2005 | 04:08 PM
RA122225's Avatar
RA122225
Banned
Also, what is the absolute worst-case scenario this could be?
Old Jul 16, 2005 | 04:50 PM
RA122225's Avatar
RA122225
Banned
Come on people, I need an answer.
Old Jul 16, 2005 | 05:12 PM
andym's Avatar
andym
So.... I guess we only get an hour and a half before you get impatient and demand an answer, huh?
To answer your question, it's not normal. In addition, your dealer is lying to you.
Old Jul 16, 2005 | 05:17 PM
chrono4's Avatar
chrono4
yea, um the thing with the dealer, thats why trucks have a open front diff. during sharpp turns, id bet that your tire are hittin your radius arms.i now that my 88 with 31 hits the arms.
Old Jul 16, 2005 | 05:22 PM
RA122225's Avatar
RA122225
Banned
Yes, and no. I was getting impatient because 26 people had viewed it, and no one had commented. I am not buying it from a dealer, I am buying it from an individual, I called the dealer on the issue, and that is what they said.
It only happens in 4wd HI, and 4wd Low, not in 2wd. I was in a field, but it was not wet, could the wheels have not had enough slippage, and caused the clunking sound? It only happens on turns.
Old Jul 16, 2005 | 07:39 PM
tjc transport's Avatar
tjc transport
i ain't rite
what size tires are on it?? if they are to big they will hit on a full lock turn. also try driving it with the transfer case in 4x4, but with the hubs unlocked.it sounds like there may be a bad ujoint somewhere, or tire rub.
