Do I or don,t I
Old Jul 16, 2005 | 01:28 PM
blue ranger's Avatar
blue ranger
Question Do I or don,t I
I have a 90 ranger 2.3 5spd i,m wondering if i have a MAP sensor or not . I called a local ford dealership an he kept saying MAF instead . I checked my chiltons manual it said it,s located on the passenger side firewall. The reason why is that I the black smoke problem all ranger owners encounter.
Old Jul 16, 2005 | 03:47 PM
87 XLT's Avatar
87 XLT
A quicklook at a GOOD wiring diagram-like the Ford EVTM- will tell you which one you have. But, even the pathetic wiring diagram in the Chiltons should tell you.
If it has a MAF it will be in the intake tube between the air filter housing and throttle body with 4 wires attached.
Have you pulled any codes?
Checked for a leaking fuel pressure regulator?
Old Jul 16, 2005 | 04:18 PM
blue ranger
I have pulled codes everything pass. I was thinking fuel pressure regulator also ,but that was changed last year could it be bad .
Old Jul 16, 2005 | 05:02 PM
87 XLT's Avatar
87 XLT
Probably not the FPR then.
Your Haynes manual will tell you how to check fuel pressure. This will tell you if you have a leaky injector.
Strange that your not at least getting an O-2 rich code.
You dont happen to have a mysterious coolant leak do you?
