Sponsored by: Auxito
Only in Canada
Old Jul 16, 2005 | 11:57 AM
DMch's Avatar
DMch
Only in Canada
My day time running lights are not working. I guess there is a relay for these but were is it? The Haynes book dosn't have much to say about it. The dealer wants over $100.00 bucks for it.
Has any one ever changed one and if so were is it and is there a cheaper place than the dealer? A junk yard might be a good place to start .
Thanks
Old Jul 16, 2005 | 05:33 PM
triton_2002's Avatar
triton_2002
I believe the sensor for the lights is under the long oval piece on the passenger's side of the dash. Any chance something is blocking this area?
Old Jul 16, 2005 | 05:45 PM
Wilbert's Avatar
Wilbert
a
All,
I've got a 98 150 extended cab, 4wd. It has no daytime running lights. Should it?
If not, what year did this feature start?
Thanks,
Wilbert
Old Jul 16, 2005 | 07:22 PM
stuart1's Avatar
stuart1
You could sure help with some information about the vehicle.
Old Jul 16, 2005 | 11:36 PM
hood's Avatar
hood
DMch,
the links below explains the DRL components, where the parts are located, and how to add DRL's if it's an american bought truck.
I ordered the parts from my local ford dealership and added the DRL feature to my 2002 F150.
http://www.voicenet.com/~storm/drl/
http://www.geocities.com/skyjet1/DRL.html
-hooD
Old Jul 16, 2005 | 11:40 PM
3 of 7's Avatar
3 of 7
There is a **** on the left hand side of the dash, If you pull it all the way out, not only will the headlights come on, but the tail lights as well.....much better than the reduced wattage the DRL have and a lot more visible..
The DRL on my Grand Marquis quit a year ago and I see no reason to fix them , because the first thing I do after starting it up is turn the lights on, it's realy not a big thing.
Old Jul 17, 2005 | 07:55 AM
DMch's Avatar
DMch
For a $130.00 relay I think I'll stay with turning the ****. If I ever sell her and have to ge t here safetyed Do you require DRL?
For Wilbert Its only in Canada
I switched the head lights to the high output Sylvania Blue about 4 years ago. The dealer said these might have caused the relay to burn out. They said they have seen wiring harness burnt because of these bulbs.
Old Jul 17, 2005 | 08:50 AM
bumpzter's Avatar
bumpzter
Originally Posted by 3 of 7
There is a **** on the left hand side of the dash, If you pull it all the way out, not only will the headlights come on, but the tail lights as well......
Love it.
xplict
6.4L Power Stroke Diesel
Sep 11, 2011 06:08 PM
Bowstring
Jul 8, 2007 03:55 PM
51dueller
17
Apr 2, 2006 12:03 AM
F150daniel
20
Apr 6, 2003 11:21 PM
