e4od help
Old Jul 15, 2005 | 07:34 PM
fordtrucksrulz's Avatar
fordtrucksrulz
e4od help
Hello, the 1st problem i have with my tranny is when taking out it is as if it is in 2nd gear and shifts down to 1st as truck starts moving, thought it was a loose trans. mount for long time, or spring wrap up. 2nd problem is when driving in city traffic or limits of 45 and lower, when it gets to od it will not shift for a long time and when it does it shifts hard, if i listen and barely lift on gas pedal it will shift normal, both problems are consistent regardless if od button is activated or not.
Any and all help appreciated.
Old Jul 16, 2005 | 01:00 PM
jim henderson's Avatar
jim henderson
You didn't give a lot of detail on the truck, year model engine miles etc.
But sounds like your tranny is slipping.
How is the fluid? Color, smell, last time changed, what was in the pan when changed etc?
I am not a tranny expert but I would drive it gently on a very smooth road and try to feel the shifts in all gears. It should be smooth without a lot of RPM jumps between gears. Also do you notice any kind of rumble, like driving on grooved pavement? If you have the rumble or shudder that is often a sign of a converter going.
Any harsh shifting? Any flashing OD light on the shift stalk?
Good luck and tell us a little more,
Jim Henderson
Old Jul 17, 2005 | 06:24 PM
fordtrucksrulz
Thanks Jim
I've got a 1995 f150 4x4 351w. After rereading owners manual I think it shifts alright into od after all. I drove it extensively without radio playing and everything seems and sounds good there. The fluid is good too, but I'm getting ready to change it (60k miles) which is why I'm inquiring about it. The other problem still has me puzzled. Whether od is on or off it still feels like slack in driveshaft or rearend, from red light to red light etc, or as if it doesn't fully shift into 1st till throttle is pressed, but I've shifted manual with same results. I can not find any slack in drive line to cause this.Also the od light does not blink at all. Do you know what the tps voltage is at idle. Thanks again.
Old Jul 22, 2005 | 10:15 PM
fordtrucksrulz
re: e40d help
Thanks Jim
