Sponsored by: Auxito
Door buzzer-Where is it?
Old Jul 15, 2005 | 11:17 AM
3dr97150's Avatar
3dr97150
Can someone point out this lovely little noise makers location(97 f150 scab 4x4).I've had all I can handle so I would like to find it and render it noiseless unless it has ill affects on something else.Any help would be welcomed!thanks,jeff
Old Jul 15, 2005 | 11:32 AM
l-m tech's Avatar
l-m tech
it is located inside the GEM(generic electronic module) or CTM(central timer module).the module is located on top of the fuse panel inside the vehicle.2 bulk connecters with a 10 mm socket then remove the fuse panel.the mod. rides piggy back on the panel.i have been wanting to do it myself but i dont know if it will effect any other system.
