8.8" or 10.25" ?
Old Jul 15, 2005 | 10:30 AM
mikeyswood's Avatar
mikeyswood
8.8" or 10.25" ?
I am about to switch a 302 M5R2 over to a 351W ZF5 and I would like to know if there is any benefit to switching diffs in a 94 150.
Thanks for your input,
Mike
Old Jul 15, 2005 | 02:07 PM
andym's Avatar
andym
It really depends on what you want to use the truck for. Generally, if you need the heavier axles, then the half ton is not enough truck for you to begin with. From a strength perspective, the 8.8" will hold up fine to even a moderately built 351.
If you do decide to switch to a 10.25", then you'll either have to do something to the front to make the lugs match, or carry two spares.
