e4od problems
Old Jul 15, 2005 | 10:12 AM
4030eddie's Avatar
4030eddie
e4od problems
I have a 92 f250 4x4 with 7.3, e4od. The truck and transmision have 118,000 miles. The transmissiion has a banks shift kit. My problem started yesterday with the rear abs light staying on, the od flashing and the speedomerter reading "0" then jumping around while the tranny is shifting very hard. I tried disconnecting the batteries and waiting 15 min, which did not work. The transmission was serviced 5000 miles ago and there is plenty of fluid. I am not really clear on how to retrieve the codes or what to do next. Any advice would be greatly appreciated.
Old Jul 15, 2005 | 01:38 PM
butch a 250 d's Avatar
butch a 250 d
sounds like the abs /speed sensor in the rear dif its either failed or the wires got chafed off or broke thats wat was wrong with mine the trans goes into limp mode
good luck
butch
Old Jul 15, 2005 | 02:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 4030eddie, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 15, 2005 | 02:31 PM
4030eddie's Avatar
4030eddie
Butch, Thanks for the info. I will take a look at the abs/speed sensor. Is there any tricks to removing the sensor? Thank you!
Old Jul 15, 2005 | 02:36 PM
butch a 250 d
i think its a 10 mm bolt on top of the rear dif remove the bolt and keeper then i twist and pull the sensor out i do not know how to test the sensor but i am sure that someone on here will know how to
Old Jul 15, 2005 | 10:27 PM
4030eddie's Avatar
4030eddie
Butch, Thank you for the advice! I replaced the abs/speedo sensor and that fixed the problem. $30.00 for the sensor and 5 minutes to pull and replace it. Thanks again.
Old Jul 16, 2005 | 08:52 AM
PLC7.3's Avatar
PLC7.3
4030..... there are three things that will send the E40D into limp mode which you were in, VSS(speed sensor), tach unreliable, and the FIPL setting(fuel injection pump lever). VSS ohms must be between 900-2500 measured between the terminals.
