Running Too Rich
Old Jul 15, 2005 | 12:09 AM
DMBronco's Avatar
DMBronco
Running Too Rich
I have a '94 Bronco, 5.8L, with about 150k miles. I just moved to Colorado from Virginia, and at the emissions inspection, it barely passed the HC portion of the test. Apparently it is running too rich. The air filter has less that 3,000 miles on it, so it should be getting sufficient air.
Is there some form of adjustment I should make to compensate for the altitude?
Any suggestions?
thanks
-david
Old Jul 17, 2005 | 11:46 AM
LxMan1's Avatar
LxMan1
It should compensate itself. You might check the fuel pressure regulator and make sure that no fuel is in the vacuum line to the regulator. If it has a MAF, it will compensate for the airflow into the engine.
ZOOT
23
May 3, 2013 09:33 AM
lilsmokey
Jul 30, 2012 12:33 AM
cfpinz
Dec 18, 2011 11:03 PM
Fandini
Oct 14, 2011 09:33 PM
monstertrucker
1983 - 2012 Ranger & B-Series
Jun 6, 2010 03:40 PM
