Stalling problem update please advise....
The problem still exists: It could be -50, the engine will start fine and run perfectly. If its about 80* it starts, stalls, starts then surges, after a few minutes things settle down and everything is fine. Restarting a warmed up engine is not a problem.
Its the first start when the weather is hot, or if it sits an hour or so on a hot day I have the same starting issues.
Any other suggestions would be greatly appreciated. I had a code 23, all codes are clear and now getting code 11.
Thanks
Frank D
